by falvarez » Mon Aug 26, 2013 8:58 pm
If you are talking about aluminum plate (i.e. 1/8" and 3/16"), I used the Arbor Press with a v-block and a small piece of 1" pipe. I think there is an EAA Hint For Homebuilders video showing the technique...if you can't find it let me know and I'll post a link.
In the case where the piece was too small for the v-block, I just put it in a vice (with aluminum protecting the jaws) and hit it with a rubber mallet.
With these two techniques, I was able to pretty much bend all the metal for the project to a fairly accurate degree.
If you were asking about the thin sheets being formed over wood blocks, I just barely rounded the wood block off (maybe 1/16" radius).
Frank Alvarez
Sonex #800, Aerovee 2.1
