scratch builder question
Postby sonex 1614 » Mon Aug 26, 2013 8:29 pm
I am cutting some forms for bending various parts. What radius' did you use? so far I found 1/8, 1/4, 1/2".
Tony
Sonex 1614
Chicago Area
sonex 1614
Re: scratch builder question
Postby falvarez » Mon Aug 26, 2013 8:58 pm
If you are talking about aluminum plate (i.e. 1/8" and 3/16"), I used the Arbor Press with a v-block and a small piece of 1" pipe. I think there is an EAA Hint For Homebuilders video showing the technique...if you can't find it let me know and I'll post a link.
In the case where the piece was too small for the v-block, I just put it in a vice (with aluminum protecting the jaws) and hit it with a rubber mallet.
With these two techniques, I was able to pretty much bend all the metal for the project to a fairly accurate degree.
If you were asking about the thin sheets being formed over wood blocks, I just barely rounded the wood block off (maybe 1/16" radius).
Frank Alvarez
Sonex #800, Aerovee 2.1
falvarez
Postby sonex 1614 » Mon Aug 26, 2013 11:59 pm
There were some clips made of .060 aluminum that called for a 1/8 radius. And a few other thicker parts like you mentioned. I know some builders have made hardwood blocks to make the radius of the .060 and thicker material so they had a nice consistent bend to form the part. I am a new builder so it is all a learning experience for me. I greatly appreciate the help and advice!
Tony
Sonex 1614
Chicago Area
sonex 1614
Postby falvarez » Tue Aug 27, 2013 8:23 am
I agree that on the .060 that the blocks should help you achieve a good radius. I was able to bend the .060 on a small 24" brake so for that I used the technique where you add extra sheets of metal to the bend to give you the radius that you need. But a wood block would have worked just as well....and may have been easier.
You can never have too many tools and tricks at your disposal when building :D
Also, I am continued to be amazed at some of the things builders come up with...there a times when it just seems too difficult to form a part or mount something....then read through other builder sites and see some creative way that makes it simple...its also a great way to get a visual queue for whatever parts you are building before you actually attempt it. I think the Sonex Foundation guys have pulled together a pretty comprehensive list of these sites.
Frank Alvarez
falvarez
Postby Bryan Cotton » Tue Aug 27, 2013 5:38 pm
A rule of thumb is the radius of the bend should be at least 4 times the thickness.
Bryan
Postby sonex 1614 » Wed Aug 28, 2013 12:22 am
Thanks for the replies.All great info!
Tony
Sonex 1614
Chicago Area
sonex 1614
Postby sonex892 » Wed Aug 28, 2013 4:20 am
I found this page on the Aircraft Spruce website which may help answer your question
http://www.aircraftspruce.com/catalog/p ... malloy.pdf
Steve
Sonex 892
sonex892
Postby dcstrng » Wed Aug 28, 2013 6:54 am
sonex892 wrote:I found this page on the Aircraft Spruce
Super table... thanks for posting...
-- Larry
Sonex Plans #1621
dcstrng
Postby EricS » Wed Aug 28, 2013 9:02 am
A very useful tool to have around the shop is AC43.13 1b/2b. For those not familiar, it's basically the mechanic's bible for standard practices. If you've got questions about hardware, cables, sheet metal, fluid lines, etc, this will guide you in the right direction.
Aircraft Spruce has them available for $20. http://www.aircraftspruce.com/catalog/bvpages/ac4313act.php
Eric Seber
Waiex #153
Jasper, Indiana
http://www.mykitlog.com/EricS/
EricS
Postby sonex 1614 » Thu Aug 29, 2013 1:12 am
Thanks guys!
Tony
Sonex 1614
Chicago Area
sonex 1614
Users browsing this forum: Google [Bot] and 91 guests
