dirkverdonck wrote:Hi All,
This is how I installed the fuel valve and it's remote control. Just remove the handle from the valve and install it so it lines up correctly, install the handle and the remote control. The reason for this set-up is to avoid side loads on the fuel valve which might cause it to leak at some stage.
sonex1374 wrote:Wes,
This is what you need. Russel Fitting PN 614206.
https://www.summitracing.com/parts/rus-614206/overview/
Jeff
lgsievila wrote:Hi Wes,
I do know of a couple of instances where Teflon tape was restricting flows but it looks like you used some sort of pipe dope. For those using Teflon tape remember to use the tape designed for gas/oil.(not the white stuff). See you next time I am in your neighborhood.
dirkverdonck wrote:Hi Wes,
The Onex is doing perfectly fine and reached the 100 hrs mark last weekend during a long trip through Holland.
