Postby GordonTurner » Wed Sep 11, 2019 6:33 pm
Never heard of that technique but it makes PERFECT sense!!!!
Postby Rofomoto » Thu Sep 12, 2019 1:02 pm
First Prototype of canopy opening mechanism.
Lever pivots at lower hole.. pulls latch back and spring loaded lever pops up canopy frame.
I have one more iteration of this System in the works to see which is best.
1735
Longassproject
Rofomoto
Postby GordonTurner » Thu Sep 12, 2019 2:02 pm
While you’re on it....how about incorporating a reliable latching mechanism that doesn’t require a pin to make it reliable....like what I’m seeing here :)
Gordon
Postby Rofomoto » Sun Sep 15, 2019 11:59 am
I jump around a lot but everything needs to be done.
1735
Longassproject
Rofomoto
Postby Rofomoto » Sat Sep 21, 2019 8:46 am
As I jump around some more... toe in
1735
Longassproject
Rofomoto
Postby Rofomoto » Mon Sep 23, 2019 11:00 am
Working on brake cable install
Also... anyone use this kind of wheel bearings?
1735
Longassproject
Rofomoto
Postby Rofomoto » Wed Sep 25, 2019 6:11 pm
Some may remember Back when Made the left side forward fuselage side I put a rear spar slot up top and decided to keep going and figure it out later. Well here is my solution.
1735
Longassproject
Rofomoto
Postby Rofomoto » Wed Oct 02, 2019 7:02 pm
1735
Longassproject
Rofomoto
Postby Rynoth » Wed Oct 02, 2019 9:05 pm
That looks very clean! However to my uneducated eye, I do wonder if that high point in the flexible hose routing might be a trap for bubbles/air? It's a little hard to tell from the pictures if relative to aircraft-level any bubbles will return to the tank.
Postby Rofomoto » Wed Oct 02, 2019 9:25 pm
Rynoth wrote:That looks very clean! However to my uneducated eye, I do wonder if that high point in the flexible hose routing might be a trap for bubbles/air? It's a little hard to tell from the pictures if relative to aircraft-level any bubbles will return to the tank.
No clamps on yet. It will be all down hill.
1735
Longassproject
Rofomoto
Return to Photo Album
