by SvingenB » Wed Mar 14, 2018 2:28 am
Decided to mount oops fitting, now rather than later. One 1/8 fitting for the fuel measurement tube, and one large for the fuel outlet. Has anyone done this, on the "old" tank with molded fittings? According to the instructions, the large oops fitting must be mounted straight down, vertical on the bottom, not horizontal like the molded fitting. It's impossible to see anything in there, so before drilling the 1 inch hole at the bottom, I would like to hear experiences from others. The molded fittings causes protrusions inside that may cause problems. (have already drilled for the 1/8 inch fitting)
