inventor wrote:I also bought one of those small CO detectors at Walmart. I am hoping to use a co detector connected to my onboard computer eventually but have the portable unit if I don't get er done in time to fly. I know someone who was killed by CO in the cabin of an airplane, so nothing to play around with in a small cockpit. Thanks for the reply.
On our return from Airventure, we had a CO situation that I'm really glad Gary had an active CO monitoring system. Our exhaust pipe had separated from the muffler. We mistakenly thought it wouldn't be an issue. But 10 Minutes into the next leg showed we were approaching dangerous levels. We returned to the last stop and fixed the muffler issue. Those CO cards with that blister tablet that turns black can tell you may be dying are fine, but they don't tell you the level. By the end of our return, I was actually feeling some effects of it, headache, etc, 10 minutes in. The SuperBee will have a similar system Gary had. Mobile, tells you the CO level, and around $150 from Amazon. Used by HVAC guys. Sealing rivets is fine. But the real issue is the vacuum of the cockpit from the outside. It literally sucks in all the air coming out of the cowl. The 10 minutes we had the issue, I held the CO monitor in various positions in the cockpit and adjusted various vents. Near the feet, much higher, near our faces, lower. The more we closed the cockpit, the higher the CO. Flip the vents to blast air in, the CO would drop. But not enough.
