Postby WesRagle » Sun Aug 25, 2019 7:21 pm
Yep, that looks like a good line as it sits. I forgot you were installing a Corvair until I saw the mount.
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
WesRagle
Postby Rick524 » Sun Aug 25, 2019 7:33 pm
Be sure to mark center front and rear of the canopy in relation to the windshield and aft fuse. Make certain the canopy is
lined up with the center marks when you are test fitting the canopy. Put new tape on your canopy and slowly creep up to
the tape when you are cutting/sanding the edges. Be ready for multiple on/off test fits before you are done.
I doubt you will have any problems anyway, just sayin.
Rick
Sonex 524
C-GRIX
Rick524
Postby Rofomoto » Sun Aug 25, 2019 7:59 pm
Good call Rick. Just sitting on there now.
1735
Longassproject
Rofomoto
Postby Rofomoto » Tue Aug 27, 2019 5:44 pm
Real stuff cut and fit!! Template worked perfectly
1735
Longassproject
Rofomoto
Postby Rofomoto » Tue Aug 27, 2019 5:46 pm
How did everyone bend in side panels? With lexan in or out?
1735
Longassproject
Rofomoto
Postby WesRagle » Tue Aug 27, 2019 5:56 pm
Lexan out. I seem to remember the most forward hole difficult to dimple after bending. Might want to handle those before bending.
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Prince P Tip 54x50
WesRagle
Postby Rofomoto » Tue Aug 27, 2019 6:37 pm
Thanx Wes
1735
Longassproject
Rofomoto
Postby Area 51% » Tue Aug 27, 2019 6:42 pm
In the your mileage may vary, I have the angles written down at each hole, if you need a reference.
And by all means, dimple at least the forward 2 holes before bending.
Area 51%
Postby EdW » Tue Aug 27, 2019 11:11 pm
Rofomoto wrote:Thanx Wes
Eagles? Are they getting back together to make a new recording?
EdW
Postby Rofomoto » Wed Aug 28, 2019 11:52 am
Lol. I hope not. That band is terrible
1735
Longassproject
Rofomoto
Return to Photo Album
Users browsing this forum: Google [Bot] and 4 guests
