Postby GordonTurner » Mon Aug 19, 2019 11:02 pm
Thanks Ryan. I was wondering about the same thing.
Gordon
Postby sonex892. » Mon Aug 19, 2019 11:50 pm
I think the for and aft in the controls there are different. I think the bolt is tight and the outer surface of the bush is the bearing. If you look there is a sintered bronze washer on this one which must be clearanced with the bush.
Steve
Lazair kit 1981 sold
Sonex kit 2010
Sonerai 2LS project rotax 912
sonex892.
Postby Rynoth » Mon Aug 19, 2019 11:54 pm
I'd be surprised if any of the flight control bushings would be intended to rotate within a drilled aluminum hole for fear of embiggening/ovaling the aluminum versus the machined/harder bolts and/or steel pushrods.
Edit: I may have misunderstood the question, my point is that the bushings shouldn't be rotating within aluminum. There are places (and your control assembly question may have been exactly this) where the outside of the bushing allows the steel assembly to rotate around it (like at the idler.) So to backtrack on my previous statement, I think for the control stick assembly the bolt actually clamps onto the bushing when the nut is tightened and the assembly rotates around the bushing.
Sorry for the confusion.
Postby Rofomoto » Tue Aug 20, 2019 6:29 am
Makes more sense now. Thanx
1735
Longassproject
Rofomoto
Postby Area 51% » Tue Aug 20, 2019 11:18 am
Plans page CO1 detail F, note: Rotation to occur between Bushing and Plate on the Control Stick Frame.
Postby Rofomoto » Tue Aug 20, 2019 1:07 pm
Area 51% wrote:Plans page CO1 detail F, note: Rotation to occur between Bushing and Plate on the Control Stick Frame.
Thanx Randy.. I saw that but didn’t realize what the plate was. billy
1735
Longassproject
Rofomoto
Postby Rofomoto » Sun Aug 25, 2019 4:08 pm
All day making a windshield pattern.
1735
Longassproject
Rofomoto
Postby WesRagle » Sun Aug 25, 2019 4:18 pm
Hey Billy,
You probably already know this, but ...
Back in the day, if a Sonex was built strictly according to plans, the cowl, windshield, and canopy didn't flow smoothly over the top to the turtle deck. The windshield was a little low at the bow. I think a lot of folks raised the the windshield just a little at the bow to get that smooth line.
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
WesRagle
Postby Area 51% » Sun Aug 25, 2019 5:36 pm
For what it's worth...the distance I have from the bottom of the instrument panel cross tie, to the top of the bow strap is 16 1/4in. Haven't had it out in the daylight to eyeball the transition to the canopy, but it looks pretty good in the shop. I'll send you a picture.
Postby Rofomoto » Sun Aug 25, 2019 6:39 pm
My cut line tape that came on this is nowhere near close
1735
Longassproject
Rofomoto
Return to Photo Album
