bakerde36 wrote:Hi Wes,
That is what I use is the Craftsman deep socket. I have a question what size is your prop? I think I am over pitched as I can only get about 3100 static and 3150 in cruise wot. My prop is Prince P Tip 54x50
I have 95 hours on my 2400 and love it, but still hope someday to have a little more horses.
Hi bakerde36,
BTW, What's your real name?
I haven't flown yet but have purchased a P Tip 54x50. I have no experience with either the Hummel 2400 or Prince props so sorry, I can't comment. I am surprised at the small split between static and WOT RPMs. Maybe that is just the way a P-Tip is. I don't know.
I do enjoy hearing from those that have flown.
Gordon Baxter is flying a Hummel 2400 with a 54x48 P Tip. Some of his reported numbers can be seen here:
http://sonexbuilders.net/viewtopic.php?f=5&t=11&p=36973&hilit=speed+run#p36973. Gordon, if you're lurking out there, do you have a number for static RPM?
I have some questions for you.
Can you report TAS at 3150 RPM?
I know all prop manufactures have their own method for specifying pitch. I've noticed over time that with P-Tips it seems to work out that if you calculate TAS with zero prop slip you'll be pretty close.
Ex. (((3150 Rev/Min * 50 in/rev) / 12 in/ft) / 5280 ft/mile) * 60 min/hour = 149.15 miles/hour. Is that close?
What EGTs do you run?
How did you tune the carb? Is it a Zenith carb? I'm thinking I need to tune the Zenith so that EGTs stay just in limits during takeoffs and low level WOT runs.
BTW, cold air induction is the only "easy" way I know of to get more power. I know folks don't believe me (by the awkward silence after I say it) but with cold air induction I could spin the AeroVee powered Sonex I used to have up to 3750 at WOT for right at 150 mph. The arithmetic suggests about a 10% increase in power by not feeding your engine cylinder head heated air.
Any other information you can share would be appreciated.
Wes
