DCASonex wrote:Billy,
Are you sure you can get that thing out of there when completed ??
Rofomoto wrote:Can someone explain to me what part pivots on control assembly where it mounts to front spar carry through tunnel? Is bolt stationary and bushing pivots on bolt? Is bolt and bushing stationary and assembly pivots on outside of bushing? Thanx for any help. Billy
Rynoth wrote:Rofomoto wrote:Can someone explain to me what part pivots on control assembly where it mounts to front spar carry through tunnel? Is bolt stationary and bushing pivots on bolt? Is bolt and bushing stationary and assembly pivots on outside of bushing? Thanx for any help. Billy.
The bolt should pivot within the bushing. You want the movement to be between the bushing and the steel bolt, not the bushing and (softer) aluminum. Sometimes you have to ream out the bushings a little bit if the bolt is too tight to pivot freely.
Rofomoto wrote:Rynoth wrote:Rofomoto wrote:Can someone explain to me what part pivots on control assembly where it mounts to front spar carry through tunnel? Is bolt stationary and bushing pivots on bolt? Is bolt and bushing stationary and assembly pivots on outside of bushing? Thanx for any help. Billy.
So the bushing should be a press fit in assembly?
