Too many holes..
Too many holes..
Postby SP1 » Sun Aug 18, 2019 12:51 pm
Found this piece. Looks like previous owner drilled too many hole in the one part. There isn’t a corresponding hole in the part that it abuts against.
Should I replace the part or can I drill through and add additional blind rivets?
SP1
Re: Too many holes..
Postby mike.smith » Sun Aug 18, 2019 1:24 pm
I don't see any reason why you can't add rivets there.
Postby NWade » Sun Aug 18, 2019 1:44 pm
On a tangent to your original question: What part is at the left edge of the photo, that we can just barely see? There appear to be several holes drilled which are right at the edge of the material! Those are no good, as the resulting fasteners are likely to rip out under load (look up “edge margin” or “edge distance” in your favorite aircraft homebuilding book or in FAA AC43.13b)
Take care,
—Noel
Sonex #1339
NWade
Postby SP1 » Sun Aug 18, 2019 2:30 pm
Thanks for looking and finding that. It’s the tail section. T04-01.
If I replace that too with a new piece from Sonex, wouldn’t the holes just map to the same place, and I would making the same mistake again?
An alternative is to replace with a channel with the longer lip.
I may be the market for a new horizontal stabilizer....
SP1
Postby peter anson » Sun Aug 18, 2019 9:19 pm
From your photo, it looks like the bend radius in the clip is too big, locating that end of the rib too far inboard. The bend radius is supposed to be 1/8". If that is the case, you just need to make a new clip from some 0.060" sheet and a new rib.
peter anson
Postby SP1 » Mon Aug 19, 2019 10:51 am
Peter,
Thanks very much for taking a look. That makes absolute sense. I think what happened was that the ownerfit the rib to the clip, and not the other way around.
SP1
Return to Sonex
