Oil Monitoring Program
Postby GraemeSmith » Mon Aug 12, 2019 6:31 pm
Anyone else got their AeroVee on an Oil monitoring program?
Just got my first report back from Blackstone and the figures are compared to a "Fleet Average". But no idea how many are in that fleet.
Graeme JW Smith
GraemeSmith
Re: Oil Monitoring Program
Postby GraemeSmith » Tue Aug 13, 2019 1:09 pm
Well Blackstone (who I use) tell me they have 5 AeroVee's under monitoring and just became the 6th.
Graeme JW Smith
GraemeSmith
Postby WesRagle » Tue Aug 13, 2019 1:23 pm
I had planed on using this guy once my plane was up and flying. Seems like a guy that is involved in auto conversions might be a bit more in tune with the experiential market. Not sure.
https://flycorvair.net/?s=Oil+Analysis
Might be worth a call to see how many VWs he has in his data base.
EDIT: I gave Larry a call and he doesn't have that many VWs in his database either. He stressed that the usefulness of oil analysis is the trend. For new engines he recommended starting the analysis at the 25 hour oil change. He also recommended flushing the oil cooler at the 10 hour oil change to get any "breakage" that may have accumulated during the initial break in out of the system so that the 25 hour oil change would give good results on which to base the trend.
Wes
P.S. I've worked myself into a bit of a pickle with the fuel system so I'm sitting at the keyboard looking for answers :-)
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
WesRagle
Postby Darick » Thu Aug 15, 2019 2:26 pm
Yes, I've sent just one sample of my AeroVee to Blackstone at the five hour oil change. The next one will be at 15 hours.
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
Darick
Postby WesRagle » Thu Aug 15, 2019 6:42 pm
Guys,
How much does Blackstone charge per sample?
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Prince P Tip 54x50
WesRagle
Postby Darick » Thu Aug 15, 2019 8:07 pm
$28.00. They send a sample bottle free, then when you send the sample back in, send the money. It's all in the instructions inside the sample bottle/box.
Darick Gundy
Sonex #1646
N417DG
Darick
Postby WesRagle » Thu Aug 15, 2019 8:32 pm
Thanks Darick,
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Prince P Tip 54x50
WesRagle
Postby Bryan Cotton » Thu Aug 15, 2019 10:59 pm
My plan for oil monitoring: check the level before I fly!
Postby Onex107 » Fri Aug 16, 2019 9:06 am
Bryan Cotton wrote:My plan for oil monitoring: check the level before I fly!
Yes, oil analysis is costly, and pretty boring until something starts to go wrong. Then it's worth every penny.
OneX 107
N2107X
Onex107
Users browsing this forum: No registered users and 26 guests
