I posted this over on the yahoo groups but though someone reading here might find this usefull as well.
I just finished fixing one of my wing attach bolt holes that ovaled out when it was drilled. I found a great solution for those that have the same issue. I bought a set of three adjustable reamers that went from just under 3/8" to just over 7/16". I was able to slowly upsize the holes by running the reamers through the entire attach point (wings, and fusealage upights) with the wing installed. I up sized about 1/32 each pass. I ended up with a perfectly snug fitting hole for a 7/16" bolt and all the ovaling was completely gone.
The best part is that the reamers are on sale at Enco right now. Go to
www.use-enco.com and search for part number 890-8858. The set of reamers is on sale for about $16.
#554
