by n502pd » Fri Aug 02, 2013 1:09 pm
OK, I am confused again and need some help! Looking at -wo8 sheet for scratch building, at main spar, the end of -w10-02 aft web, shows 6 holes that mount rib #3, as WS 32.75", on both spars. If I correctly understand the stack up of the web and spar caps, -w10-02 aft spar web has a gap of .125 inch between it and the main spar web. When rib 3 is riveted inplace, without some sort of spacer here, the webing will bend incorrectly at the outboard end of w10-02. I am thinking there is a spacer somewhere that goes here to prevent this, but I cant find it. Is there one? Where is it shown? Or do I have the stack up wrong? or worse yet cant read?! thanks! Joe, SN 1510 :?
Joe Nelsen
scratch built :D
Flying @78.2
KGYI/N. Tx Reg/Perrin Field
