Removing wheel from main gear titanium strut
Postby pschwenn » Wed Jul 17, 2019 2:07 pm
I need to replace the entire wheel assembly on one of the forward main gear struts of a taildragger. I removed the bolt that holds it on, but even with a small sledge hammer and flat nosed chisel I can't move it at all. Is it possible that heating all but the titanium strut itself would release it?
Thank you, Peter Schwenn
6514 41st Ave
University Park MD 20782
240-602-6931
N16XN under construction
N32SX @ KCGS (912iS being installed)
http://www.schwenn.com
Eaa4 - KCGS College Park MD
pschwenn
Re: Removing wheel from main gear titanium strut
Postby DCASonex » Thu Jul 18, 2019 8:15 am
Did you build the plane ? If not, sounds like someone may have used epoxy as the axle sockets are normally a rather loose fit on the gear legs and require some thin shims. If epoxied, some heat of up to about 350 deg. F might loosen it enough.
Users browsing this forum: No registered users and 69 guests
