To secure a pesky short pin on my custom cowl mod for a Jab 2200 sump,
I made a little stainless clip riveted to the cowl that secures the 1/2" right angle bend on the end of the wire.
It holds against the bent bit by spring tension, a little joggle in the clip tab stops the pin rotating past.
Easy to flip over the wire end from the clip and bend the clip back at the same time with a finger and pull out the wire.
Sounds more complicated than it is, but works well.
I uploaded a quick sketch of how it looks..
- cowlclip.jpg (18.32 KiB) Viewed 4208 times
Cheers
