Throttle Cable setup?
Discussions for ULPower engines.
Postby dtibbo » Tue Jun 25, 2019 8:28 pm
I have a UL 260iS, and the throttle cable attaching to the engine is posing a small issue.
I've installed the throttle cable as recommended, and it bows before getting to full throttle. The slack means I'm going to get a non-linear throttle response...
In the Homebuilt Help video, they've solved this issue with a piston-style throttle end attachment. But that piston and accessories are sold by Zenith, only to Zenith owners. So I can't get my hands on that particular kit. Anyone know something similar I could try?
David Tibbo
Former Marine EA-6B Navigator, Civilian Instrument pilot
Waiex-B delivered 14 Nov 2018
Airworthiness certificate 11 June 2020
dtibbo
Re: Throttle Cable setup?
Postby sonex892. » Wed Jun 26, 2019 4:39 pm
ACS have throttles with the solid piston at the carb end.
I use an A800 on a bing carb. I had to modify the arm on the carb to reverse the shaft rotation from pull to open to push to open.
https://www.aircraftspruce.com/catalog/ ... kkey=12964
Steve
Lazair kit 1981 sold
Sonex kit 2010
Sonerai 2LS project rotax 912
sonex892.
Return to ULPower
