A couple of questions
Re: A couple of questions
Postby Rofomoto » Tue Jun 25, 2019 9:48 pm
WesRagle wrote:Hi Guys
Question: How do I leak test it?
Any ideas?
Wes
Wes hook up a regulated air compressor to no more than 5lbs. of pressure after sealing all openings. Go around all fittings and seams with a spray bottle of windex while looking for small bubbles to form.
Billy
1735
Longassproject
Rofomoto
Postby WesRagle » Tue Jun 25, 2019 10:38 pm
Hey Billy,
Sorry for being dense, but how do I hook the fuel tank to a compressed air source?
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
WesRagle
Postby Rofomoto » Wed Jun 26, 2019 5:35 am
WesRagle wrote:Hey Billy,
Wes
3/8” male air hose fitting... put cap on tank and put pipe plugs in all other holes. The hose fitting screws in the same place the fuel shut off valve goes.
1735
Longassproject
Rofomoto
Postby Rofomoto » Wed Jun 26, 2019 10:34 am
I think the 3/8” male hose fitting is the same as on probably your air rivet gun. Just use that.
1735
Longassproject
Rofomoto
Postby WesRagle » Wed Jun 26, 2019 10:35 am
Duh ...
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Prince P Tip 54x50
WesRagle
Postby WesRagle » Wed Jun 26, 2019 4:19 pm
Hey Guys,
Well, the fittings for my air tools did *not* fit the fuel valve port in the tank.
However, my bride of 42 years agreed to go on a quest. She found a fitting I could use.
I turned the regulator down on my air compressor to show 5 P.S.I. Not trusting the very old regulator/gauge to be accurate at that low of a pressure I "filled up" a portable air tank and took a reading with a digital pressure gauge.
Close enough.
I then hooked up the pressure hose and turned the air on. It was a little alarming to watch the flat sides of the tank bulge out. But, do the arithmetic. Five P.S.I. * surface area is a lot of force.
I tried using Windex but it foamed up a bit when it was sprayed. Then I remembered, while my wife was out she picked up some bubbles for my Grandson. Serendipity!
I pored some "bubbles" into a container and used a brush to apply them.
Ne'er ye a Fubble.
So, I feel pretty good about the "fix". I'll get the tools packed up and sent on to Rob within the next couple of days.
Thanks for all the help guys.
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Prince P Tip 54x50
WesRagle
Postby Rofomoto » Wed Jun 26, 2019 6:45 pm
Glad to see it worked. Nice job!
1735
Longassproject
Rofomoto
Postby WesRagle » Wed Jun 26, 2019 8:53 pm
Guys,
Here is the current inventory of the Oops fitting install kit:
1) Tool for large fitting.
2) Tool for small fittings.
3) Abrasive material.
4) A step drill bit turned down to 5/8" for the small fittings.
5) A 7/8" step drill if you would like to follow Sonex's instructions and finish the large fitting drill out with a "twist" bit.
6) I'm throwing in the 1" step drill bit I bought for the large fitting drill out as my contribution to the cause.
7) Instructions.
Rob, the kit will be sent out to you tomorrow.
After you are finished with the kit, please coordinate with Jerry and take care of him. Ref. (
jerryhain wrote:I’d like to be next in line for the tools. I bought a YX to fly while I build my OneX and it seems to have developed a slow leak.
And guys, please ,when y'all are finished, make sure the kit makes it back to David with the $8 I've included to cover his cost. His address is included on the instruction sheet.
I'll send Rob a PM to make sure he's aware.
Thanks again to everyone for all the help.
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Prince P Tip 54x50
WesRagle
Postby WesRagle » Fri Jun 28, 2019 6:50 pm
Hi Guys,
With the Oops Fittings behind me, I'm back to FWF. On this build I'm going to use the Zenith carb. So, I'm required to implement carb heat. Once implemented I need to determine it's effectiveness. I've been looking at various carb ice curves.
Ex.
It appears to me that if I can devise a system that produces a 50 Fahrenheit Degree temperature rise in induction air temperature, that would always drive me out of possible icing conditions.
Am I interpreting the curve correctly? Has anyone out there built and tested a system? Comments?
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Prince P Tip 54x50
WesRagle
Postby WesRagle » Tue Jul 09, 2019 11:38 pm
Hi Guys,
OK, I've given it my best shot at implementing carb heat. I built a simple flapper valve on the air box to get carb heat off of a heat muff. I have an old heat muff I cut down years ago for use on a VW pipe but I ended up not needing it.
What I need now is a longer version of the same muff that I can modify for carb heat. Captain Google yielded this:
However, Wicks tells me that they no longer offer the part and that the manufacturer has gone out of business. So, I find myself in need of a long stainless steel heat muff for use on the VW (1-3/8" I think) exhaust pipe.
Question: Does anyone know where I can purchase a stainless steel heat muff for use on the standard AeroConversions stainless steel VW exhaust?
Thanks For Your Time,
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Prince P Tip 54x50
WesRagle
