Oil Pressure Spikes
Re: Oil Pressure Spikes
Postby lgsievila » Sun Jun 23, 2019 9:32 pm
Hey Mark, just a question-Do you have the sensor mounted directly to the engine?
Loren Sievila
Conventional Gear Onex33
CAMit 2200
Dynon Skyview
lgsievila
Postby tx_swordguy » Mon Jun 24, 2019 10:23 am
I do. it is the angled position above the other hole. been working fine for 14 months and 80 hrs since I bought the plane. It just recently started acting up. I bought another vdo unit and keep it in the plane for the time it totally goes south on me.
Mark Whiddon
T25 Aero Estates
Sonex N889AP
jabiru 3300 solid lifter
tx_swordguy
Postby lgsievila » Mon Jun 24, 2019 3:04 pm
Hi Mark
I sent you a PM
Loren Sievila
CAMit 2200
Dynon Skyview
lgsievila
Postby sonex892. » Tue Jun 25, 2019 4:47 am
tx_swordguy wrote:I do. it is the angled position above the other hole. been working fine for 14 months and 80 hrs since I bought the plane. It just recently started acting up. I bought another vdo unit and keep it in the plane for the time it totally goes south on me.
Mark These senders are prone to fail, its only a few minutes work to change the sender if you already have one its probably worth giving it a try.
I had a slowly decreasing oil pressure and added a washer to the relief valve, it brought the pressure indication up and I was happy. I later calibrated the sender with an air compressor adjusting the regulator and ohm meter. Turned out the sender was getting stuck and giving the same resistance output from 30 psi right up to 80. When I put a new sender on the pressure was was actually a bit too high from adding the washer.
From memory I think a vdo 5 bar unit increases 10 ohms for every 5 psi
Steve
Lazair kit 1981 sold
Sonex kit 2010
Sonerai 2LS project rotax 912
sonex892.
Postby WesRagle » Tue Jun 25, 2019 4:33 pm
lgsievila wrote: Of course I have an orifice in the oil line going to the sensor in case the line would break so I wouldn't lose all my oil at once.
Hey Loren,
Where did you get the orifice for the Oil Line?
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
WesRagle
Postby woodmw » Tue Jun 25, 2019 11:59 pm
Wes...I don't know if any are available commercially. I made one using an AN fitting, AN816 in my case. Plug one end, clamp in vise, and heat with torch to melt solder to fill it up. When cooled, drill tiny hole through solder. .035-.05 should do. If you want more bite inside the fitting for the solder to form to, you could run a tap through it.
woodmw
Postby rick9mjn » Wed Jun 26, 2019 9:18 am
Wag-Aero , has the then in their catalog.....see part # A-123-003.......restrictor fitting................
.....good day / rick
rick9mjn
Postby WesRagle » Wed Jun 26, 2019 9:32 am
rick9mjn wrote:Wag-Aero , has the then in their catalog.....see part # A-123-003.......restrictor fitting................
Hey Rick,
Thanks. I just didn't know what to call it. Once I checked Wag-Aero and found out it was a "Restrictor Fitting", google magically started working again :-)
Thanks Mike. They are available, so I'll just order one.
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Prince P Tip 54x50
WesRagle
Postby woodmw » Wed Jun 26, 2019 10:44 am
Wes....I'm like you. Didn't know what to call it. Think I'll order one for the "T".
woodmw
Postby lgsievila » Wed Jun 26, 2019 11:07 am
Hi Wes
Similar to woodmw I just made my own orifice. Sounds like some folks have found commercial ones available.
Loren Sievila
CAMit 2200
Dynon Skyview
lgsievila
