Rofomoto wrote:What # drill bit for leading edge skin have you used pre- dimpling. Thanx billy
Area 51% wrote:It says specifically on page W07 not to use a #30. The holes can end up too big after the dimpling causing proud rivet mandrels and the possibility of the rivet pulling completely through. It calls for either a 31 or 32.
Seems to me I remember someone offering a dimple die set that has a 3/32 pilot for the 1/8 rivets. Then you can open up the holes to 1/8in after the process.
GordonTurner wrote:Maybe larger than you will need.....I ran a twisted pair of 18GA to each wingtip for landing light (+ and -), plus a shielded 3-conductor 20GA for:
NAV
STROBE
STROBE SYNC
shield for ground.
Gordon
