by inventor » Wed Jun 19, 2019 6:07 pm
I had a problem since the vertical bulkhead parts had slots that interfered with using bushings through which to route the cables. I fabricated plates to cover the slots and hold the snap bushings. The bushings are 3/4" od and are split, allowing the cable to be inserted by pulling apart the split. The cable ends can be pushed through the id although it is a tight fit. Bushings sourced on Amazon, 100 for about $10.
- Attachments
Onex 150
