VDO pressure sender
VDO pressure sender
Postby Onex107 » Tue Jun 18, 2019 12:28 pm
Has anyone found a source for the 0-80 psi sender that costs less the $50? It's failing at 250 hours.
Re: VDO pressure sender
Postby WaiexN143NM » Tue Jun 18, 2019 1:42 pm
hi all,
Try the swift press sender avbl from aircraft spruce.
#04056 0-150 psi
#04057. 0-100 psi
1/8 npt
Postby Onex107 » Tue Jun 18, 2019 7:47 pm
The MGL EFIS recommends 0-80 psi. and only take one wire to the panel. What's the three wires for on the Swift?
Postby XenosN42 » Tue Jun 18, 2019 9:32 pm
250 hours? Count yourself lucky - no very lucky. Buy another VDO.
-- Michael
OneX N169XE
XenosN42
Postby WaiexN143NM » Wed Jun 19, 2019 2:18 am
onex 107, all,
the swift has 3 wires, +5v, gnd, and signal. john austin on the zenith site has a detailed posts on how to hook up the swift sender to MGL equipment. posts were last fall.
www.zenith.aero
hope this helps......
u could just buy another vdo for the same price, but expect it to fail again in about 200 hrs.
michael.
