Postby Rofomoto » Wed Jun 05, 2019 5:37 pm
Bottom side pilot drilled.
1735
Longassproject
Rofomoto
Postby Rofomoto » Sun Jun 09, 2019 10:27 am
All rear skins on and up drilled. My question is how much leveling must be done when time to fit leading edge skin or is it pretty much set now that the rear skins are drilled and clecoed? Thanx billy
1735
Longassproject
Rofomoto
Postby Bryan Cotton » Sun Jun 09, 2019 1:24 pm
Clecoes allow a fair bit of movement. I always rechecked when I moved stuff around. We are talking 5-10 minutes with a level, at least how I was set up.
Postby Rofomoto » Sun Jun 09, 2019 2:03 pm
another question... when bending forward skin with the vacuum method was the 1 1/2" pvc pipe placed centered over the leading edge reference line shown on plans? Also has anyone used spray glue to help hold tube to skin? thanx again billy
1735
Longassproject
Rofomoto
Postby Rofomoto » Sun Jun 09, 2019 3:19 pm
1735
Longassproject
Rofomoto
Postby Area 51% » Sun Jun 09, 2019 3:55 pm
From my experience, no matter what you try to do to hold the pipe in place, the skin will do it's best to form equal distances from the pipe to the edges. I used flat factory skins. The only way I was able to get the correct bend line was to add a strip to the short side (bottom) offsetting the trailing edges. You have the luxury of being able to trim the skin after forming.
Area 51%
Postby Rofomoto » Sun Jun 09, 2019 4:42 pm
Area 51% wrote:From my experience, no matter what you try to do to hold the pipe in place, the skin will do it's best to form equal distances from the pipe to the edges. I used flat factory skins. The only way I was able to get the correct bend line was to add a strip to the short side (bottom) offsetting the trailing edges. You have the luxury of being able to trim the skin after forming.
That’s why I have the tabs on the bend line with the holes for bolting down tube to skin to table.
1735
Longassproject
Rofomoto
Postby Area 51% » Sun Jun 09, 2019 5:22 pm
I don't think it will matter much. Unless the distance from the bend line to the edges is the same, the skin will wrap itself toward the short side effectively relocating the bend line.
I went through 2 skins before I saw what was going on. Whatever happens, you're going to love the radius.
Area 51%
Postby sonex892. » Sun Jun 09, 2019 8:18 pm
Hi Billy
I like your thinking of using tabs to secure it for the bend. But I suspect the leading edge adjacent to the tab might resist being bent and you may end up with a squarish leading edge at each end. I'd try bending a test piece with scrap before risking all your good work.
I re bent the factory leading edges using the vacuum method. It's a great idea, just make sure your table is dead flat.
Steve
Sonex 892
Steve
Lazair kit 1981 sold
Sonex kit 2010
Sonerai 2LS project rotax 912
sonex892.
Postby sonex1566 » Mon Jun 10, 2019 4:25 am
Hi Billy,
I used black electrical tape to hold everything in place when I did it. Also I was too chicken and cheap to cut the skins to size and drill the pilot holes before bending as I was worried about things moving. I used plastic shopping backs to seal the ends and a heap of electrical tape to seal it all up. It takes half an hour to seal it up and about 3 Seconds to suck the bend. My way is harder when it comes to marking out the holes as you have to measure from the chord line over the curved leading edge.
Richard
Scratch build Sonex
Std gear, dual control
Jabiru 3300, Sensenich prop
19-8776
1st Flight 25th June 2019. 170 hrs so far.....
http://www.sonex1566.com
sonex1566
Return to Photo Album
Users browsing this forum: Nick and 3 guests
