Dead Stick landing (kinda)
Postby fastj22 » Fri Jul 05, 2013 10:07 pm
Had a "fun" flight this morning. I've been tweeking my cooling ducts and decided to take her up for a few laps around the dog patch to see the results. Everything was fine until I decided to land. I reduced throttle to no avail. It just kept the same RPM. A few more laps around and I couldn't figure out what the problem was. Decision time. How do I land? I decided to climb a 1000ft above pattern and see if I can restart the engine after mixture cut off. It works. So back in the pattern, I make a long approach and pull the mixture. Too high and too fast. Full mixture, engine restarts and do a go around. Next time I cut it on base. I'm high, but know I can slip it to the numbers. I come in real fast. No flaps, just hold until touchdown. A few bounces and I'm down and off the runway.
Back at the hanger, I find the bowden cable sleeve had pulled out of the aerocarb bracket. When I pulled full throttle, it worked normally, but when I pushed to idle, the sleeve just moved up and the throttle slide didn't move.
I caught the episode on video.
http://youtu.be/_eg_KFe74Bg
Re: Dead Stick landing (kinda)
Postby N111YX » Sat Jul 06, 2013 6:16 am
Nice job getting it down! I know that's not the first time that has happend. Bob Mika had his throttle cable break on final at OSH-in the idle position!
If you have not already considered it, you might try one of these...
http://www.aircraftspruce.com/catalog/appages/a920.php
It's worked fine for me. I have a Bowden cable on the mixture.
Kip
Jabiru 3300 #1637 and #3035
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1175 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Postby fastj22 » Sat Jul 06, 2013 9:25 am
How do you connect the push/pull cable to the aerocarb and throttle quadrant?
Postby N111YX » Sat Jul 06, 2013 10:28 am
Threaded forks and rod ends do the trick.
fastj22 wrote:How do you connect the push/pull cable to the aerocarb and throttle quadrant?
Kip
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1175 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Users browsing this forum: No registered users and 84 guests
