Second flap done....now for the last big things..the dreaded wing assembly.. still have 8 more aft ribs to make then ready....a little over a years work so far.
1735 Longassproject E-A-G-L-E-S Eagles (next year 16- 0)
Before I rivet # 9 rib in one last check with you guys if it matters if control horn hits the lightning hole? Don’t know if control ever get this far...
Rofomoto wrote:Before I rivet # 9 rib in one last check with you guys if it matters if control horn hits the lightning hole? Don’t know if control ever get this far...
It's not a problem, the controls never get that far. If you look at 0:18 and 0:40 in this video of mine you'll see how close it gets to the lightening hole. There's nearly a full inch of clearance when the aileron hits the stops. You would probably run into issues of the shorter bellcrank>aileron pushrod binding up before the bellcrank reached the lightening hole anyway.
Video was taken after having pre-rigged the shorter pushrod, so the travel of the bellcrank should be about the same as what you end up with:
[quote="dbdevkc"]Mine are very close, but do not hit. But like you said, I'm not sure it matters.
Left
Thanx kevin..really should know before assembly... maybe someone else may know if the movement actually travels through lightning hole at full deflection thanx billy
I think I bent the hole flange a bit just to be sure. With an inch of clearance it probably doesn't matter but it made me feel better at the time.
Bryan Cotton Poplar Grove, IL C77 Waiex 191 N191YX Taildragger, Aerovee, acro ailerons dual sticks with sport trainer controls Prebuilt spars and machined angle kit Year 2 flying and approaching 200 hours December 23
