by Darick » Sun Apr 14, 2019 4:48 pm
I have eight hours on my AeroVee with the smiley face cowl opening. However it is fully covered with an aluminum plate with three evenly spaced 3/4" holes (subject to correction after I get to the hangar to verify hole size). Just last week with air temps in the sixties, I had the center hole open and oil temps were 180-190. I suspect even with summer temps I'll never need the full opening. The holes are plugged as required with plastic snap-in covers from Ace Hardware aviation dept.
My #1 cylinder temp are now under control after replacing the black rubber baffle seal at the back of the cowl, with the red rubber stuff from Aircraft Spruce. There is a post in my photo album, page 16, with a picture.
Also, I think my AeroVee is running great although I don't have another one nearby to compare it. I'm using the K&N washable air filter and the 2.5 needle. Other pilots around the airport say it sounds good, but loud.
Darick on Sun Apr 14, 2019 5:32 pm, edited 1 time in total.
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
