by DCASonex » Fri Apr 12, 2019 9:03 am
The three important thing about installing fuel pressure sensors is same as buying real estate, location, location, location. At the low pressures of the Bing fuel system, the height at which the pressure is sensed relative to the bowl of the carb can make a significant difference. Try to install it as close to same height as possible. Also elevation of the pump makes a difference, if down low at bottom of cowl with collator, it will need to pump up to carb, but if located higher, more of its pressure appears at the carb. Also running with the 40105 pump, and some times see about 3.5 psi, have not had any problems of fuel flowing out, but do often see a bit in the balance tube, which runs uphill from bottom of carb to my intake, so is trapped there.
