Postby Rofomoto » Thu Apr 04, 2019 10:55 am
So I’m riveting the left hand spar and the countersunk rivets are on the rear side of the spar. My question is when I get to the outboard end, which way do the round head rivets go in? It seems to me they should go in from the forward side through the thinner material first. Thanx for any help. Billy
1735
Longassproject
Rofomoto
Postby Rofomoto » Thu Apr 04, 2019 7:28 pm
Got my answer from local eaa rv builder. Left spar riveting done.
1735
Longassproject
Rofomoto
Postby Rofomoto » Thu Apr 11, 2019 12:10 pm
those of you kit builders did your leading edge skin come with all holes drilled? Even the line that attaches to the spar? thanks drawing up the skins now
1735
Longassproject
Rofomoto
Postby Bryan Cotton » Thu Apr 11, 2019 12:56 pm
Yes, especially the holes that line up with the spar. Aft spar and skin holes set the location of the aft skin. Aft skin sets location of pilot holes in the spar. Those holes then locate the forward skins. And, of course, you look through the holes to see the blue lines on your rib flange before you drill.
Postby Rofomoto » Thu Apr 11, 2019 5:16 pm
Bryan Cotton wrote:Yes, especially the holes that line up with the spar. Aft spar and skin holes set the location of the aft skin. Aft skin sets location of pilot holes in the spar. Those holes then locate the forward skins. And, of course, you look through the holes to see the blue lines on your rib flange before you drill.
The plans on SNX-W18 forward wing skin show no line of holes for spar attachment area.
1735
Longassproject
Rofomoto
Postby Bryan Cotton » Thu Apr 11, 2019 5:30 pm
https://www.sonexaircraft.com/documents ... W07-02.pdf
Near the top of page 2 it says to cleco the fwd skin to the spar.
Postby Rofomoto » Thu Apr 11, 2019 5:48 pm
I saw that but I’m plans building and so I layout all my holes. The plans show no line of holes for where the skin meets the rear skins. I could transfer the line of holes shown on the rear skins but how far back from edge is what I would need to know. Thanx
1735
Longassproject
Rofomoto
Postby Rick524 » Thu Apr 11, 2019 8:15 pm
Hi Billy, I plans built my wings many years ago. I looked at the plans and think this is what I did.
Put all the holes in the aft wing skin 1/4" from the edge as plans show. Place it on the spar and transfer
the holes to the spar. Put a line 1/4" from the trailing edge of the forward wing skin. Side it under the aft
skin so the line is visible thru all the pilot holes on the aft skin. Drill and cleco all the holes. Pull out the
forward skin, debur then put it on top of the aft skin and rivet.
I hope that's what you were asking.
Rick
Rick524
Postby Rofomoto » Thu Apr 11, 2019 8:23 pm
Rick524 wrote:Hi Billy, I plans built my wings many years ago. I looked at the plans and think this is what I did.
Rick
Exactly what I needed to know Rïck. Thank you
1735
Longassproject
Rofomoto
Postby Area 51% » Fri Apr 12, 2019 2:34 pm
Don't know why there would be any difference between the Waiex and Sonex wing, but the hole edge distance on my leading edges is 3/8in. as well as the aft skin at the spar. The trailing edge of the aft skin is, however, 1/4in.
Area 51%
Return to Photo Album
