by Rick524 » Wed Jun 26, 2013 2:00 am
You need a strap duplicator. Aircraft Spruce have them, or you can make your own. Very easy to
make. I drilled my doublers using one and it came out perfect.
You just need to get the doublers close to the right size so they will sit on the wing in the proper
place. Then use the duplicator to drill the rivet holes and cleco the doubler in place. Then make
a spacer with a small hole in it 3/16" from one edge for a sharpie to fit into and slide it around the
wing to make a mark on the doubler. Then remove the doublers and carefully trim to your line.
Put the doubler back on and check the gap. If all is good, you're done!
Lazer shmazer, I'm a scratch builder too. lol.
Rick
Sonex 524
