rwthomas1 wrote:Hello All,
I introduced myself in a previous post, I have an almost completed tricycle gear Sonex I want to convert to a taildragger. I have searched the forum, but not found exactly what I want, so I'll ask.
Looking at the plans, it appears that this is relatively simple. The bottom aft fuselage is not installed yet so I have access to the interior of the tail, no problem. Order/fabricate tailwheel mount parts, and tailwheel assembly.
The conventional main gear attach to the engine mount, so that part is as simple as ordering a new engine mount, gear legs, etc.
Looking at the existing main tricycle gear mounts in the fuselage, under the seat, it seems like a bit of work to remove them, with not much to gain except loosing a bit of weight. Am I correct in thinking to simply fabricate plugs for those holes and be done with it?
This doesn't look all that difficult, am I missing something?
Thanks, RT
Users browsing this forum: Google [Bot] and 20 guests
