Bryan Cotton wrote:Yes, especially the holes that line up with the spar. Aft spar and skin holes set the location of the aft skin. Aft skin sets location of pilot holes in the spar. Those holes then locate the forward skins. And, of course, you look through the holes to see the blue lines on your rib flange before you drill.
Rick524 wrote:Hi Billy, I plans built my wings many years ago. I looked at the plans and think this is what I did.
Put all the holes in the aft wing skin 1/4" from the edge as plans show. Place it on the spar and transfer
the holes to the spar. Put a line 1/4" from the trailing edge of the forward wing skin. Side it under the aft
skin so the line is visible thru all the pilot holes on the aft skin. Drill and cleco all the holes. Pull out the
forward skin, debur then put it on top of the aft skin and rivet.
I hope that's what you were asking.
Rick
