by Darick » Tue Apr 02, 2019 8:18 am
Yep, same problems here...solved with the red baffle seal from ACS...see page 16 on the photo album Darick's Sonex...
I also noticed the factory seal, which I kept in place at the sides and front, and have come in contact with oil, have become sticky, soft, gooie which is a sign of incompatibility with oil. I suspect it may be EPDM rubber (ethelyene propolyene) used mainly for water exposure. Silicone rubber, the red stuff sold by ACS for baffle seal, has the best qualities for heat and oil resistance.
Not to blow my own horn but, my work experience for 30 years in the fluid power business was solving problems with sealing devices made of all kinds of rubber and plastics...buna/nitrile, viton, Teflon, nylon, etc.
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
