Bryan Cotton wrote:One thing I forgot to mention - if you put the fitting in like I did, it protects the wires from the edge of the firewall. I was going to install it like in Ryan's picture and then I had an epiphany.
I like your solution!
For what it's worth, in the ACS kit installation, the wires are protected from any firewall/metal edge contact by wrapping the wires in some of the fireproof sleeve passed through the fitting itself. Besides protecting the wires from chafing, I assume this also helps to make a better fireproof seal on the engine-compartment side (more meat for the full sleeve to clamp onto.) It was done by taking the sleeve and cutting down the middle of it lengthwise to make it a smaller diameter to stick through the opening. You might consider using the same method even in your install. Here's some pics:
You can see in the bottom picture that the outer sleeve is wrapped around the inner sleeve which is wrapped around the wires.
