by Area 51% » Sun Mar 24, 2019 5:21 pm
That strap being 3/4 of an inch short is not the end of the world, or even undesirable, especially if you opted for the machined components like we did. On our Waiex, the factory made hole in the longeron that the bow passes through is close enough to the outside edge that there's not enough room for both the lexan and the strap. With both in place, the fuselage skin gets pushed out.
Not having a working canopy yet, I can't say what impact that lack of strap section may have on it's fit. It looks like it may provide a small water inlet or a large slipstream noise-maker. Either, or both, was more desirable to me than having tension on that skin section.
The real problem with the strap for us wasn't so much that it was short, but it didn't match the bow front-to-back. Since the windscreen had already been trimmed to fit the bow, (yes, we removed the same 1/2in or so at the bottom of the lexan) a new strap was in order. Because of it's length, that turkey required a very pricey sheet of stock from which to cut it.
If you're going to Sun-N-Fun and need a piece for a longer or different shaped strap, let me know and I'll cut you a slice.
