Postby Rofomoto » Fri Mar 22, 2019 10:36 am
While I’m waiting on aircraft spurce, back to my tail wheel. Can anyone tell me the weight of their wheel assembly? Trying to compare with my mine. Thanx Billy
1735
Longassproject
Rofomoto
Postby Area 51% » Fri Mar 22, 2019 11:59 am
I've got a Peter Anson unit. Half nylon-half aluminum wheel with the 6in pneumatic tire. Not including anything except the pivot/wheel assembly, I get 700grams or 24.7oz or 1.55lbs.
Postby Rofomoto » Fri Mar 22, 2019 12:33 pm
Area 51% wrote:I've got a Peter Anson unit. Half nylon-half aluminum wheel with the 6in pneumatic tire. Not including anything except the pivot/wheel assembly, I get 700grams or 24.7oz or 1.55lbs.
Thanx again!!!
1735
Longassproject
Rofomoto
Postby Rofomoto » Fri Mar 22, 2019 7:48 pm
All dimpled and countersunk. Tomorrow clean up parts, cleco, and rivet. (Still a mess here)
1735
Longassproject
Rofomoto
Postby sonex892. » Sat Mar 23, 2019 1:56 am
Rofomoto wrote:While I’m waiting on aircraft spurce, back to my tail wheel. Can anyone tell me the weight of their wheel assembly? Trying to compare with my mine. Thanx Billy
Hi Billy
I recently removed my original old solid tailwheel and installed a 6" pnuematic tire, steerable, full swivelling unit. If you are going the 6" pnuematic definitely go a higher quality black scooter tire in lieu of the grey wheelchair tire. The grey ones wear real quick, I also had one blow out on a landing I would rather forget.
732 grams is the weight of the old original 4"
Steve
Sonex 892
Steve
Lazair kit 1981 sold
Sonex kit 2010
Sonerai 2LS project rotax 912
sonex892.
Postby Rofomoto » Sat Mar 23, 2019 3:05 am
Looks like my modified scott tailwheel weighs about 2010 grams or 4.4 lbs. I am using a heavier engine so I guess we’ll see how weight and balance turn out.
1735
Longassproject
Rofomoto
Postby Rofomoto » Sat Mar 23, 2019 9:24 am
Getting ready to rivet my first spar I noticed a screwup. I dimpled and countersunk 7 holes to far on the top spar. Will substituting those hole with flush rivets be a problem? Guess I’m trying to go to fast. Thanx
1735
Longassproject
Rofomoto
Postby Bryan Cotton » Sat Mar 23, 2019 9:45 am
I'd ping Sonex tech support for the official answer. But, a dimple into a countersink will give you better shear strength than a universal head rivet. Seems fine to me. On my Hummelbird I did flush rivets on the entire center spar for ease of assembly. They only called out flush where the brackets for bolting in lay against the spar. That was approved by the designer. Different airplane so that is more of an anecdote.
Postby Rofomoto » Sat Mar 23, 2019 9:54 am
Thanx Bryan
1735
Longassproject
Rofomoto
Postby Rofomoto » Sun Mar 24, 2019 11:59 am
So I’m practicing the bolt method to do the rivets. Do the round head rivets have a flat on them from the bucking bar when set? Thanx again. Billy
1735
Longassproject
Rofomoto
Return to Photo Album
