Postby Rofomoto » Mon Mar 11, 2019 2:38 pm
Area 51% wrote:We have, and used 200 +-. Wanna borrow them?
Where do you live? Thanx
1735
Longassproject
Rofomoto
Postby Rofomoto » Tue Mar 12, 2019 6:20 am
builderflyer wrote:I don't know what Sonex typically sells for spar caps extrusions these days but I hope you'll insist on getting the raw, uncut version like we had to deal with in the "good ole days", 20 years ago. You wouldn't want to cheat yourself of the experience of measuring the raw extrusion 3 times and still cutting it incorrectly as some were known to do.
In any event, you plans builders are to be congratulated and appreciated. There seems to be less and less of you all the time.
Art,,,,,,,,,,,,,,,,,Sonex taildragger #95,,,,,,,,,,,,,,,,,,Jabiru 3300 #261 (14th year of flying and still lovin' it)
Art funny you should say that. I looked for the raw extrusions but couldn’t find a source. Billy
1735
Longassproject
Rofomoto
Postby Bryan Cotton » Tue Mar 12, 2019 6:29 am
Those are custom Sonex extrusions, made for Sonex only. You won't find them elsewhere.
Postby Area 51% » Tue Mar 12, 2019 7:09 am
Tim Wrede is currently (the last I knew) in possession of my bucking bar. If you need one, you might check with him to see if he's through with it. I thought I hear on a pod-cast he had his wings complete.
Area 51%
Postby builderflyer » Tue Mar 12, 2019 9:55 am
Billy,
Bryan is correct. The spar cap extrusions can only be purchased from Sonex and their general rule was that only one set of spar caps would sold per set of plans. This rule kept builders from reusing one set of plans thus requiring a builder to buy a set of plans in order to build the airplane. However, I do recall reading about at least one "cheap" builder who redesigned the wing without the "special" extrusions in order to be able to cheat Sonex out of their plan fee. Too many frugal builders like this would have put Sonex out of business in the early days.
So what I was suggesting is to buy the raw uncut version of the spar caps from Sonex, if they'll still sell them that way. Maybe they'd be less expensive and then you'll get to enjoy the full scratch built building experience, having to cut them yourself.
builderflyer
Postby Rofomoto » Tue Mar 12, 2019 11:16 am
Area 51% wrote:Tim Wrede is currently (the last I knew) in possession of my bucking bar. If you need one, you might check with him to see if he's through with it. I thought I hear on a pod-cast he had his wings complete.
Thanx. I have a bucking bar but only two dozen or so black clecos. If you want to let me barrow them I’ll send money for shipping. Thanx Billy
1735
Longassproject
Rofomoto
Postby Rofomoto » Tue Mar 12, 2019 6:49 pm
Got the spar caps today!!! They fit perfectly
1735
Longassproject
Rofomoto
Postby Rofomoto » Wed Mar 13, 2019 12:24 pm
I have pilot drilled all the angle fittings for the spars. Now ready to pilot drill the spar caps. My question is when pilot drilling is done in spar caps , do i attach all the angle fittings with 3/32 inch clecos and drill to final size? Or do you up drill angles pieces separately from the already pilot drilled angles? Thanx Billy
1735
Longassproject
Rofomoto
Postby racaldwell » Wed Mar 13, 2019 1:04 pm
Billy, Have all parts with silver clecoes all together and spar straight and level then updrill. Cleco to final size as you progress. Clamps are needed for the thicker area near the root. The clecoes don't have the reach or the strength.
Rick Caldwell
Xenos 0057
racaldwell
Postby Rofomoto » Wed Mar 13, 2019 1:30 pm
racaldwell wrote:Billy, Have all parts with silver clecoes all together and spar straight and level then updrill. Cleco to final size as you progress. Clamps are needed for the thicker area near the root. The clecoes don't have the reach or the strength.
Rick Caldwell
Xenos 0057
thanx Rick, so angles are all attached for up drilling?
1735
Longassproject
Rofomoto
Return to Photo Album
