Keeping engine warm while soaring
Postby peter anson » Fri Feb 08, 2019 6:32 am
A friend of mine is building a Xenos, and one of the things we have discussed is a method of keeping the engine warm while it is shut down when soaring. We were basically thinking along the lines of having motor driven shutters to cut off either the cooling air inlet or outlet. Have any Xenos flyers built something along these lines and if so, was it useful?
peter anson
Re: Keeping engine warm while soaring
Postby Rynoth » Fri Feb 08, 2019 10:16 am
Cowl flaps have existed in airplanes since forever. I imagine it wouldn't be terribly difficult to install a hinged flap for the outlet. I would avoid adding anything at the inlets though as this would be more likely to disrupt airflow, and there's not much room in that area of the cowl.
Postby bvolcko38 » Fri Feb 08, 2019 10:43 am
I built a movable cowl flap using a linear actuator. Haven’t flow enough to tell if it was worth the effort
Bill Volcko XNS0068
Aerovee and Prince P-Tip
V6
First hole 4/1/16
First flight 8/24/18
Phase I complete...finally!!!
bvolcko38
Postby racaldwell » Fri Feb 08, 2019 12:24 pm
Mine is still under construction but I will be making a friction-lockable cable operated cowl flap. I plan to attach the flap to the airframe so I do not have to disconnect it to remove the cowling. I have pondered over how to reduce or shut off airflow at the inlet but that just seems too complicated whereas the exit flap seems straight forward.
The other Xenos here in Melbourne that is under construction has a lever/pushrod operated cowl flap for the radiator exhaust air. He has the Aeromomentum engine and is currently doing taxi tests but has not flown.
Rick Caldwell
Xenos 0057
racaldwell
Postby sonex892. » Fri Feb 08, 2019 11:43 pm
Inlet flaps on a whisper motorglider https://youtu.be/N3_RgEcEvXo?t=646
Steve
Lazair kit 1981 sold
Sonex kit 2010
Sonerai 2LS project rotax 912
sonex892.
Postby peter anson » Sat Feb 09, 2019 7:07 am
racaldwell wrote:Mine is still under construction but I will be making a friction-lockable cable operated cowl flap. I plan to attach the flap to the airframe so I do not have to disconnect it to remove the cowling. I have pondered over how to reduce or shut off airflow at the inlet but that just seems too complicated whereas the exit flap seems straight forward.
One Australian Sonex builder tried a cable operated cowl outlet flap but had problems with it locking when air loaded. That's obviously a problem that could be solved but he eventually just left it locked open. I would agree that shutting off the outlet seems easier. Might also be worth considering a door to stop air flow through the oil cooler. That vertically split cowling is a bit of a curse when considering adding any of these features.
I think plenty of people will be interested to see how the Aeromomentum engine performs in the Xenos.
peter anson
Postby autopilot » Fri Feb 07, 2020 10:37 pm
I have Xenos SN 0001. I have done some soaring in Florida powered off. I never noticed any issue with engine temps going cold enough to be of concern for restart. I have the factory proto type with no cowl flaps or any modifications. I do keep an eye on the engine temps. and if I see them getting to low while soaring, I will probably just start the engine.
autopilot
Return to Xenos
