Oil leak in my Aerovee
Postby kenandkatie2 » Sat Jan 19, 2019 12:15 pm
After completely rebuilding my Aerovee after a prop strike, I'm experiencing a major oil leak. It looks like it might be coming from the rear main seal even though the one that's in there now is new. Anyone had similar problems and can shed some light before I have to remove the engine again?
kenandkatie2
Re: Oil leak in my Aerovee
Postby 9GT » Sat Jan 19, 2019 2:31 pm
Pinpointing the source location of an oil leak can be more difficult due to the fact that the oil gets blown around under the cowling and can pool in certain locations that may look like the source of the leak when it actually is coming elsewhere. I would thoroughly clean the engine of oil, add a leak detector to your oil and make very short runs until you first spot the leaking oil location. Leak detector additives are readily available from just about most auto parts suppliers. If its the rear main seal then go ahead and remove the engine and replace it. There is nothing more annoying than an oil leak making a mess under the cowling.
David Clifford
Howell & Gladwin, MI
RV-9A: Under Construction (I'm a repeat offender!)
RV-10: Built & Sold: Flying Since 2013 N959RV
Cozy MKIV: Built & Sold: Flying Since 2007 N656TE
9GT
Postby Rynoth » Sat Jan 19, 2019 4:30 pm
Here's an older thread that may shed some light:
viewtopic.php?f=7&t=2163
Postby MichaelFarley56 » Sun Jan 20, 2019 12:44 am
Ryan offers an excellent post to review, but don't be surprised if you have to remove the engine and flywheel to simply replace the rear man seal. When I first ran my AeroVee, I had the same issue and it turned out that the spring inside the rear main seal had been kinked at some point. Long story short, this allowed an unequal seal on the flywheel flange causing an oil leak. I replaced that seal and all was fixed.
I know it's a pain to remove the engine block and flywheel but don't be shocked if it comes to that. The good news is, it really doesn't take all that long in the long run and you'll be all fixed once it's done.
Good luck!!
Postby mike.smith » Tue Jan 22, 2019 12:36 am
I did a really stupid thing a long time ago when I replaced the rear seal. I ran the engine only a few hours after replacing the seal. So the RTV on it had no time to cure. Leaked like a river! Other than that, a slight bit of damage or kinking when going in could do it. What about a leaking cam plug? That's back there, too. Oil sump plate?
Postby kmacht » Tue Jan 22, 2019 7:31 am
I would guess the cam plug. The stamped steel ones are tough to get to seal correctly. They make a nice machined plug with an o ring now for under $10. If you pull tbe flywheel off also carefully inspect between the two webs on the right side of the back of the csse. It is an area the magnesium cases are known to crack. Its unlikely with a low time engine but worth a look since it had a prop strike.
Postby S1102 » Thu May 27, 2021 10:25 am
MichaelFarley56 wrote:Ryan offers an excellent post to review, but don't be surprised if you have to remove the engine and flywheel to simply replace the rear man seal. When I first ran my AeroVee, I had the same issue and it turned out that the spring inside the rear main seal had been kinked at some point. Long story short, this allowed an unequal seal on the flywheel flange causing an oil leak. I replaced that seal and all was fixed.
Good luck!!
How difficult was the removal of the gland nut. I am faced with the same effort
rory
S1102
Users browsing this forum: autopro and 58 guests
