Postby Rofomoto » Thu Jan 03, 2019 3:07 pm
Decided to go with right and left mechanical brake levers instead of toe mechanical brakes
1735
Longassproject
Rofomoto
Postby Rofomoto » Fri Jan 04, 2019 1:24 pm
Little parts take to long.... flap tube horns
1735
Longassproject
Rofomoto
Postby Rofomoto » Fri Jan 04, 2019 4:19 pm
How tight should the flap tube be in the blocks? Some resistance, easy spin or tighter resistance? Thanx billy
1735
Longassproject
Rofomoto
Postby Rick524 » Fri Jan 04, 2019 6:10 pm
So theres no slop. Without the flaps connected, the handle should stay where you put it. I'd go on the tight side rather than loose, greese up the blocks and when you attach the flaps you will get good rotation.
Rick
Rick524
Postby Rofomoto » Fri Jan 04, 2019 6:50 pm
Rick524 wrote:So theres no slop. Without the flaps connected, the handle should stay where you put it. I'd go on the tight side rather than loose, greese up the blocks and when you attach the flaps you will get good rotation.
Rick
Thanx Rick
1735
Longassproject
Rofomoto
Postby Rofomoto » Wed Jan 09, 2019 7:16 pm
Rear canopy bow
1735
Longassproject
Rofomoto
Postby Rofomoto » Thu Jan 10, 2019 10:10 pm
Flaptube and pedals finished
1735
Longassproject
Rofomoto
Postby Rofomoto » Fri Jan 11, 2019 11:11 am
Always amazed how well these parts fit. Great plans. Flap tube and handle. Just have to remove and paint.
1735
Longassproject
Rofomoto
Postby Rofomoto » Fri Jan 11, 2019 12:09 pm
1735
Longassproject
Rofomoto
Postby Rofomoto » Fri Jan 11, 2019 12:14 pm
Canopy angles
1735
Longassproject
Rofomoto
Return to Photo Album
