Flap drive tube SNX-C04
Postby Rofomoto » Sun Dec 30, 2018 9:55 am
What is the weldment in the center of -09 on flap tube for? Thanx billy
1735
Longassproject
Rofomoto
Re: Flap drive tube SNX-C04
Postby Bryan Cotton » Sun Dec 30, 2018 10:05 am
That is for center controls. I am using the center weldment but not the left side one.
Postby Rofomoto » Sun Dec 30, 2018 10:16 am
Bryan Cotton wrote:That is for center controls. I am using the center weldment but not the left side one.
Thanx Bryan
So with center controls you have to take your hand off stick to In gage flaps? Or do you still have duel sticks?
1735
Longassproject
Rofomoto
Postby Bryan Cotton » Sun Dec 30, 2018 10:25 am
Billy,
Still have dual sticks. Throttle, mixture, fuel shutoff, flaps, and handbrake are all in the middle. Fly left hand in the left seat, right hand in the right seat. Except for the Sonex hand brake and sticks instead of a yoke, it is like a Cessna.
Edit: you can see more of the controls here. The flap handle is folded down so I could get the tank in and out.
Postby Rofomoto » Sun Dec 30, 2018 11:13 am
Thanx big help!!
1735
Longassproject
Rofomoto
Postby DCASonex » Mon Dec 31, 2018 11:44 am
If wanting to keep hands on throttle and on stick while landing, consider adding an electric flap operator. 12 volt 6" linear actuators of at least 100 pound thrust capacity can be found for under $100, and if switch is next to throttle, hand does not have to move. If throttle and switch are in left lower corner of panel, can also operate the trim tab while keeping hand on throttle. Have drawings available.
Postby Rofomoto » Mon Dec 31, 2018 3:21 pm
DCASonex wrote:If wanting to keep hands on throttle and on stick while landing, consider adding an electric flap operator. 12 volt 6" linear actuators of at least 100 pound thrust capacity can be found for under $100, and if switch is next to throttle, hand does not have to move. If throttle and switch are in left lower corner of panel, can also operate the trim tab while keeping hand on throttle. Have drawings available.
Thanx David
Good option. Do you use a momentary switch for that And how does it reverse?
1735
Longassproject
Rofomoto
Postby GordonTurner » Mon Dec 31, 2018 3:51 pm
You can use either a (ON)-OFF-(ON) or a (ON)-OFF-ON switch depending how you want it to function.
The first one, you hold until the flaps are where you want, let go, and the switch returns to OFF.
The second one you hold it for the flaps going DOWN, but when you flip it UP the flaps will come ALL THE WAY UP.
Need DPDT switch in either case. The leads to the flap motor are the center poles, power and ground go to, for example, the left and right poles for up, and the right and left (opposite) poles for down.
The actuator you want to find has built in OFF when it reaches end of travel. Also, if you have an EFIS you should get an actuator with a built in position sensor so you can show flap position in the screen.
Gordon
Postby Rick524 » Mon Dec 31, 2018 5:11 pm
I think this is one actuator that has been used on a Sonex, (not mine though) I still have the handle.
www.pololu.com/product/2307
Rick
Sonex 524
Rick524
Postby Rofomoto » Mon Dec 31, 2018 5:27 pm
Thanx guys
1735
Longassproject
Rofomoto
Return to Sonex Plans
Users browsing this forum: No registered users and 34 guests
