lutorm wrote:Those are mounted up side down, they go on the bottom of the cylinders.
If you were setting up for updraft cooling rather than downdraft (in a pusher setup) would you switch the tins top to bottom, or keep them on the original sides? (assuming you had the original top tins also.) Seems to me that their shape will be optimized for airflow direction?
