by Sonex1517 » Mon May 13, 2013 7:56 pm
Well, I hadn't seen anyone post much about the matched hole construction, so here we go - photos to follow.
I started the fuselage this weekend with my sub kit that had matched hole parts. Wow!
It was like a big (expensive) erector set! I took out the parts, clecoed them to the fuselage this evening after doind some other prep work over the weekend. The matched holes in the channel line up perfectly with the holes in the side fuselage skin. Some clecoes and voila! It looks like a fuselage in the making....
Off to take a few photos.....back shortly....
Robbie
You guessed it - workin' on the fuselage!
Aero Estates (T25)
First flight 10/10/2015
375+ hours
Jabiru 3300 Gen 4
Prince P Tip
Taildragger
N1517S
