Gordon wrote: Nothing was mentioned by anyone that the bearing I see in the photo (Azusa-8256) should be discarded and changed to the Azusa-8229 bearing. This is the "upgraded" bearing that Sonex sells ($7.75 each...you need 4) and should have been provided in the kit in the first place. This bearing has the rubber seal around it to keep dirt and moisture out of the bearing AND keep the wheel grease in. This is a very worthwhile and cheap upgrade.
