Prop model and length options?
Rotax 912 series discussion.
Re: Prop model and length options?
Postby pschwenn » Wed May 02, 2018 5:06 pm
I've ordered a propeller for the 912iS Sport I'm installing. Its an Helice E-Prop Durandel 100 (it would be a 155cm or 160cm Durandal 100 Model S on Sonex or Waiex (faster planes than my Xenos which will be a Model M 165cm [given slicker wheel pants a 2 inch taller tire will give you another 10cm prop diam without slowing you down]).
It's three blade solid composite ground-adjustable. The attraction of the Durandal propellers is that the shape, thickness and very short chord-length are such that is not (simplifying) near stall over a wider regime (climb, cruise, speed, altitude) than a conventional solid propeller. And since it is ground adjustable one starts out at your chosen regimes center point. For an Aerovee 80hp it would be a Durandal 80. The supporting documentation, test results and testimonials are more convincing and simpler than other wonder props and the concept is very simple.
Price is about $1600 against $4000 - $10000 for an in flight adjustable or constant-speed, and its weight is very low because it IS a solid composite prop (with inconel(?) )protection on the leading edge.
Matching carbon extensions and spinners are available.
I will report when I finish installation.
6514 41st Ave
University Park MD 20782
240-602-6931
N16XN under construction
N32SX @ KCGS (912iS being installed)
http://www.schwenn.com
Eaa4 - KCGS College Park MD
pschwenn
Postby Brett » Sat Dec 01, 2018 3:33 am
Has anyone flown behind the Sonex recommend prop for the Rotax 912 ?
From the website they recommend the WC64QR-81G
Thanks.....
Sonex 1645
VH-VWS
Tailwheel
Former Aerovee Turbo
Rotax 912
Brett
Postby Brett » Sun Jan 06, 2019 5:56 am
Perhaps a better question would be is anyone considering using the recommended Rotax prop for the 912 in the future?
Or knows of anyone flying behind it?
Sonex 1645
VH-VWS
Tailwheel
Rotax 912
Brett
Postby Concorde » Sun Jan 06, 2019 7:59 am
Brett wrote:Perhaps a better question would be is anyone considering using the recommended Rotax prop for the 912 in the future?
I bought the 64” prince p tip but haven’t install it yet . My 912 uls arrived before Christmas so I am trying to figure everything out . I have a tri gear Sonex and according to Sonex with standard tires I should have 6”of ground clearance. I am thinking about larger tires but I will wait and see.
Ben
Sonex # 1684
Tri-Gear, Dual Control
Rotax 912uls
N379BS reserved.
Concorde
Postby Zack » Thu Sep 24, 2020 9:34 am
Any updates?
Zack
Postby Murray Parr » Thu Jan 05, 2023 5:33 pm
Does anyone have performance numbers (static rpm etc) for the early sensenich props sold by Sonex for the Rotax 912 100hp engines? The number was WC64QR-81G I believe. It would also be interesting to compare figures with the smaller diameter WC60QR-82G they sell now.
Murray Parr
WXB0015
Rotax 912ULS
MGL Explorer Lite
First flight May 6/23
RV9 builder (Sold)
Murray Parr
Postby Murray Parr » Sun Feb 12, 2023 7:42 am
I'll go first. Static runup for the early version Sensenich prop WC64QR-81G is 4900 RPM for my Rotax 912 ULS. Anyone else have any comparisons?
Murray Parr
WXB0015
Rotax 912ULS
MGL Explorer Lite
RV9 builder (Sold)
Murray Parr
Postby GraemeSmith » Sun Feb 12, 2023 8:08 am
Murray Parr wrote:I'll go first. Static runup for the early version Sensenich prop WC64QR-81G is 4900 RPM for my Rotax 912 ULS. Anyone else have any comparisons?
Check my math.
4900rpm - Reduction gearbox 2.43:1 = 2,016.46090 rpm
x 60 = 120,987.654 rp HOUR
64" diameter propeller. Circumference = Pi * D = 201.0619 inches
Circumference x rpHour = 24,326,011 inches per hour
Which equals a blade tip speed of 774mph
Must have been INCREDIBLY noisy - as well as inefficient.
With the 60 inch diameter prop we are in the realms of 726 mph
Still seems excessive.
What did I miss?
Graeme JW Smith
GraemeSmith
Postby Area 51% » Sun Feb 12, 2023 8:26 am
I'm getting 384 mph tip speed with my math.
64" diameter X Pi = 201in. X 2016rpm = 405,216 inches per minute X 60 minutes = 24,312,960 inches per hour divided by 12 = 2,026,080 feet per hour divided by 5280 = 383.73mph.
Postby GraemeSmith » Sun Feb 12, 2023 8:53 am
Area 51% wrote:I'm getting 384 mph tip speed with my math.
And I agree!
For the life of me I can't see where I was out by a factor of 2. It's not like 2 is even a number in the calculation to be screwed up. And I did it twice coming at it from either end. We need emoticons on this site so I can post a :BLUSH: one.....
Graeme JW Smith
GraemeSmith
Return to Rotax
