lutorm wrote:A 4-1, if it's properly sized, will give you better peak power than short stacks. But if yours was made to feed a turbo it's probably not correctly sized to maximize NA torque, so that's probably not a concern.
ProfJ wrote:lutorm wrote:A 4-1, if it's properly sized, will give you better peak power than short stacks. But if yours was made to feed a turbo it's probably not correctly sized to maximize NA torque, so that's probably not a concern.
Yeah, I thought that might be the case (both yes, 4-1 should be better; and yes, my 4-1 is not optimal). What is NA torque? Thanks for the input...
Users browsing this forum: No registered users and 60 guests
