by WesRagle » Sat Nov 24, 2018 12:09 am
Hi Mike,
I had a dead stick landing during the early testing of a Sonex. The idle was set too low and the engine died on final. I had the field made and so focused on landing rather than a restart. Once on the ground the engine was badly flooded and I couldn't restart and had to drag the plane back to the hangar.
After that I worked out a restart procedure.
As soon as the engine dies quickly pull mixture to idle cutoff.
Engage the starter.
Wait for the engine to fire or until five seconds have passed, whichever comes first.
Then, with the starter still engaged if the engine hasn't fired, set mixture full rich.
The engine should either continue to run or re-light.
YMMV
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
