by DCASonex » Fri Nov 16, 2018 12:05 pm
What to build depends on your interest in building vs getting into the air quickly. Nothing on the Sonex is particularly difficult, but can be time consuming depending on what you do or do not get in the way of quick build parts. If you enjoy the opportunity to use a bit of your own ingenuity to customize to your preferences and the chance to learn by doing new things, the Sonex may be your best bet. If wanting something to throw together and get in the air quickly, consider the RV12. Also, as you noted, their missions are different. The Sonex is an aerobatic rated plane that is just fun to hank and bank. But add a dual axis autopilot and it also makes for a nice cruiser, if you and wife fit it comfortably. If you are another tool nut, you will be acquiring some new stuff with either plane. For things you will use frequently, get the best you can afford, and for things like drills, be it pneumatic or battery, good quality allows for ample power while keeping small and light so that hand fatigue, which leads to errors, does not become a factor. Either way, it is likely that you will spend more time building than flying. If you like making things, set up a proper work space and invest what is needed to be able to enjoy the build,
David A. Sonex "A": TD with CAMit 3300
