builderflyer wrote:Are you sure it isn't the alternator itself that failed? If your tachometer takes its feed from one of the two alternator wires as does mine, it may explain why you lost the tachometer as well. Just wondering.
Art,,,,,,,,,,,,,,,,,,,,,,Sonex taildragger #95,,,,,,,,,,,,,,,,,,Jabiru 3300 #261
Rick524 wrote:I find the theories of removing heat from the regulator interesting. Some say they mount them on spacers
so they don't touch the firewall. I made sure I mounted mine on a thick piece of aluminum that is flush
on the firewall. I used transistor heat sink compound between the regulator and alum, and alum to firewall.
Wont the heat be conducted away from the regulator?.....guess I'll find out, lol.
Rick
Users browsing this forum: Google [Bot] and 13 guests
