racaldwell wrote:could you explain a little about what you did wrong in drilling the TI legs? I have that out in front of me and would like to learn what to do and not to do. I cannot tell from your pictures.
Hi Rick,
Just not being patient and thinking it through. After watching the Sonex EAA video, I started with a new 1/8" cobalt bit, filed a flat spot on top of the rod for the bit to be square to the rod and then used a small spring loaded centering punch to make a mark for the drill bit. I gradually stepped up the hole to 1/4" with 5/32", 3/16", 7/32" and finally 1/4".
These were my mistakes:
Not using the "V" block which I finally found later
Not marking a good center line on the rods
Using the drill vise and not using a way (via center line etc.) to make sure the bit was centered on the rod
I used Aluma Prep cutting fluid, the can said good for "mild" steel, but, I think I should have used better fluid for stainless/all metals
The drill bit wanted to wander a bit with the drill press turned on after running it down on the rod with the drill press off to check it hit the centering punch mark
After the fact, I made a centering mark on the rods (DUH) with a sharpie and square to see if the hole bottom came out true, which they didn't
I found myself trying to tweak the rod and position on the drill press to stop the slight drill bit wandering and used light and slow pressures
In hind sight, after thinking about it and watching the video numerous times, I was doomed from the start.
My new plan of attack when the time comes:
The little centering punch I used barely made a mark for the bit to start in. I have purchased a 1/4" centering punch to smack with a light hammer and leave a good indentation on a marked center line with a flat spot at least the width of the 1/8" drill bit to start in flat and square to the rods
I will use the "V" block.
I purchased the right cutting fluid from the local machine shop to use
I'll be marking the center line of the rods with a sharpie
I am also toying with the idea of inserting the legs in the motor mount, once installed and using the mount bolt pattern to drill into the leg and then transfer it to the drill press for final drilling
Here are the pictures again a little bigger
Not the best way of setting up the drill press. There were no centering references to go from
Drilled holes after marks were made to check centering. left rod is the bottom off center and right rod is top oblonged after trying to tweak for bit wobble
Holes after centering mark referenced were made. Left rod is the top on center and right rod is bottom result of said tweaking.
Sorry for such a long dissertation, I hope this helps with your legs! I got really frustrated and thought It was going to cost dearly, but, I have a second chance. Will definitely think it through and take my time...
