sport65 wrote:I have a problem with my engine loosing rpm to the point of failing with the standby fuel pump turned on (on the ground at idle). I have replaced the standby fuel pump with two different units. I used the facet 3.5 to 4.5 psi pump first (recommended by Jabiru). Changed that to a 1.5 to 2.5psi facet that had a one way check valve(only one available at correct psi from facet). I thought the check valve might be the problem, so replaced with a holley 1.5 to 2.5psi with no check valve. Same problem. The engine runs fine above idle with the standby pump on. Idles fine with the standby pump off. Engine failed on rollout with standby pump on. I have the fuel bowl level set at 10.5mm. I did that with the aircraft in a level attitude( I'm a taildragger ). I'm going to set the fuel bowl level to 12mm, but don't think that is really the issue. Any one familiar with this issue ?
Users browsing this forum: Google [Bot] and 59 guests
